- Aug 22, 2010
- 66
Hello-I found a puddle of water under my pool heater. I took the top off and found that the header gaskets are leaking. Looks like this is a cheap repair and parts are available (part R0050800 but before I take the rest apart do I need/should replace anything else when I take the heat exchange off? Also, it appears I simply need to remove a few wires, siphon loop and a disconnect supply/return to header and lift everything out. Am I missing anything?? Thank you.
