I have a Jandy CL460 cartridge filter that is 8 years old. I noticed this week that it is leaking from the bottom. I inspected it very carefully and it is not leaking from the drain plug or the band. At this point I am assuming it has a hole/crack in the bottom.
I looked into replacing the bottom. Apparently the filter has been redesigned and it will require re-plumbing to accommodate the slightly different replacement size. All in all, I estimate the cost to replace the bottom, re-plumb, etc.. will be ~50% the cost of a new filter.
If going to a new filter, I would like to move away from Jandy. I have had trouble getting simple parts through the years for my Jandy equipment. I have a Nature2 Fusion (not in use) and struggled getting the proper fitting O-rings from Jandy a while back (it is now leaking again). It's frustrating to me that I can't buy simple replacement parts. When I inquired about a Jandy SWCG recently, I was told by an online retailer they were taking business away from online retailers and going through "authorized" Jandy dealers only. I want to be able to buy parts online and replace them myself when needed.
Obviously, I don't want to pay the extra cost for a new filter if it's not necessary. Will having a new bottom with an 8 year old top/pressure gauge be perfectly fine? Or should I go ahead and purchase a new filter that will hopefully give me trouble free years ahead? And finally, if going for a new filter, what other brands would you recommend (I'm not sure where to start)?
