Leaking IntelliChlor union
uvavi8r
181
Falls Church, VA
The lower union (where is screws onto the salt cell) has a slow leak (1 drop every few minutes), this is a new install. I took the SWG out, cleaned the mating surfaces and put some magic lube on the o ring. It is still leaking. Any suggestions?
I would try replacing the O ring since it is easy and low cost.
You get your cell from your Pool Builder? Make a warranty claim on the new cell and make it the builder and Pentair problem.
Other then an O ring problem any other cause is expensive and should be a warranty claim.
