Leaking Elbow
Fishy1234
0
449
Apple Valley, CA
Discharge side of pump, pipe goes up to elboe and where elboe connects to 2 inch pipe going to Filter has a drip at the connection.
I noticed after treating spa with lots of liquid chlorine for some small green spots, Algae presumed because the chlorine seems to help.
So can I do something to stop this drip? With pump off no drip so far. It is crazy hot right now, pool temp 87 degrees. 105 air temp.
Probably. Might have someone watch it. If the water gets too low, or it breaks apart, they can turn off the pump...
I've just been mulling your pictures. When you said replaced, I decided I'd say something.
Those pipes do not look like schedule 40. Black schedule 40 is extremely shiny. Particularly the elbows, they look like DWV fitting. Here is what black schedule 40 looks like.
Who installed this and what did they represent as they were installing (material)? Maybe it is Sch. 40, but I'm suspect.
They're Waterway 411-9130 fittings painted black. My builder used these sweep 90s as well.
Reactions: PoolStored
If it was my pool, I would keep the pump running at low speed 24/7 so that pressure is low as well. If you shut the pump down, it's possible that water will drain out of the plumbing and allow air into the system. I doubt the small leak is going to develop into a major problem anytime soon.
