I just opened my pool. It's above-ground pool with a sand filter and no deck. This is the second season with my pool and I have never opened it before. I thought it would be pretty straightforward; just the reverse of what I did to close it, then chemical balancing. The hoses and caps were stored indoors but the filter and pump were left outside. For better or worse, I left the top contraption of the filter on over the winter, although covered with a garbage bag. I left the big nut that keeps that lid on outside too. I'm not sure if this was a bad idea.
Well, the chemical stuff has been easy. I did a thorough test of the whole gamut and everything is pretty good, pH started at 7.4. The pool surface was only dirty at the bottom and sides but not green anywhere, and the water was fairly clear. The problem I've had is the filter is leaking in 4 out or 6 spots where there is a hose connection. Despite this, the filter and pump work and the pressure is at about 11 PSI.
Some leaks are just a few drips -- frustrating but manageable. There are a couple leaks that are fast drips or a slow stream, which is rather infuriating. The connections are all very tight; I even used pliers to tighten some connections. I've made the clamps as tight as possible. The only advice I've seen about this is to make sure everything is tight and wiggle and re-tighten the connections. This has changed the leaking some but it hasn't stopped it. I don't know what I am doing wrong, but one thing I know is that I doubt I could hire someone to fix this for such a small job. (Since it's not a full opening and just a tightening of connections.) Maybe someone is willing to come over but I would rather not pay someone for a full opening when I've already done the filling of the pool, chemical balancing, and connecting of the hoses the best I can. I'm pretty sure I didn't lose any O-rings.
Does anyone have any general advice about this? It's frustrating. This is only the second day I've filled it so I can't tell you yet how much it's leaking, but it might be an inch of water a day. If needed I'll supply photos. It occurred to me that perhaps I could hire my local household plumber for this small job.
