Hi
I own a small 3200 gallons above ground pool. Great pool, got chemistry down, all is fine beside a leak.
The leak is at the outake, the plastic part that screws on inside and outside of the pool and where the filter outake tube connects.
Last year it was leaking and we purchased the whole replacement parts this year. Put it on, and bam, the leak is still on.
Last year we used waterproof tape and a special sealant that never dries and sticks to your hands bad. Nothing helped.
There are actually 2 leaks. One is a drip where the outake hose connects, and the other one which is worse, runs down the side. There has to be something we can do!
Please see the pictures. The running water can be clearly seen in the pics but not the drip which is right below the white part where the outake tube connects.
Thanks for reading
Pat
Thanks for reading
Pat
