We just removed cover and in the process of adding water to begin opening process of testing, treating, clearing, balancing etc. It became obvious we’ve got a leak somewhere. We’ve not started the system yet so Pretty sure it’s in the liner, but honestly, I don’t have a clue where to start. Should we go ahead and start running the pump, getting the water clear so we can at least get past the green swamp stage and better see what’s going on? Or is there something else we should do first? This is the 10th year. Last year we had a few small areas where the liner had separated from the bead which we had repaired. We did remove all the winter plugs so water has passively entered the pipes. It appears to me we’ve lost maybe a couple of inches just today. Pleases share your thoughts and advice.
