- Jun 7, 2016
- 78
- Plaster
- CircuPool RJ-60
We bought the house 5 years ago, the floor drain never worked, seemed clogged or plugged; it's a 6" circle, 4" deep with the pipe coming to the side of the hole, concrete in the hole has broken off somewhat. We installed new coping last year, had rust holes patched in the walls, and the pool re-painted. While empty I blew some air through the floor drain to see if it was clogged, didn't see anything noticeable come out, but it got it cleared. After filling it, the floor drain will work, but lets in some air when that value is open, so I assume there's there's a leak/break in the line somewhere. We also have some water loss here and there, and I assume that's the cause as well. I generally keep the value to the floor drain closed so as to not make it worse and not bring air into the lines.
What are the options to address this? Despite the air, it was super nice having a working floor drain when closing the pool last year vs. trying to drain it via the skimmers while keeping it air tight to maintain the seal. So, it's nice to have available, but the leaking water is a hassle and I'm concerned about it getting worse or letting contaminants into the water.
I'm not going to dig/cut out to install an new pipe; we just had the work done last year and without knowing where it's broken, I'm not paying that much money to fix it.
Do they make oversize drain covers, like the flat ones you can use in sinks, but big enough to place over the drain? Guessing not, and I doubt it would seal/hold the same way as in a sink.
Can you feed a smaller flex pipe down the 2" and somehow seal it at both ends?
If nothing else, can I make a big ball of epoxy putty and just stick it in the opening in the drain to seal it off?
Other options?
Other options?
