Leak in Pool, Will be away for Six Weeks, What to Do?
I would think you could temporarily plug the return line and cap the return to stop the leak. Is the pump start up related to the return leak? if not fix the pump or what is causing the loss of prime. If you have VSP let it run continuously at a low speed and a couple times a day run it at a higher speed to purge any air that may accumulate in the pump.
Additionally have someone check on the pool to make sure it not to full or low. Setting up a web cam to see the pool is a good idea too. The ability to remotely control the pump would be nice. You could also add a remotely controlled valve to add water.
Thanks everyone for the ideas. What a great feature to be able to add water to the pool via app. I have a security camera out back so I can see the level of the water from there. The water temp is at 48 right now, so too low for the SWG to kick on normally without the override. I just need to get the pump to stop sucking in air. Potentially related, I went out this morning when the pump turned on and the bottom of the pump was leaking when at high speed. The pump is 3 years and 2 weeks old, just outside of the Jandy warranty. The original installer suggested calling Jandy to see if they would work with me and they stepped up. They couldn't have been nicer about it either. Thanks Jandy! I have a tech coming tomorrow to look at the pump.
Closing off the main drains could be a great solution. It was a firm no from the wife on the quote that just came in for $5,500 to fix the leak. Still learning the pool, but have identified which pipe to the pump is from the skimmer and which is from the main drain. I switched off the main drain to see if that does anything to help. Will see tomorrow. Should that not help, is closing off the drain a DIY job? Put on my weight belt, SCUBA tank and sit at the bottom of the pool to close it off? Expandable rubber plug? I just don't know if the leak is in the pipe or where the pipe connects to the pool, so the leak is outside of the pipe.
Doubtful, the defect will leak regardless of that valve's position.
Well if you can remove the cover plate and install an expandable rubber plug, then that will probably determine which side the leak is on. If the leak stops, then leave the valve at the pad closed and you're pretty much done. If you install that plug correctly, you might not need to do anything else to close off the drain.
If you decide to do this yourself, before you remove that cover plate, turn off all the breakers to the pad. You do not want that pump coming on while you're working on an exposed suction port.
And like in all diving, don't go in alone. At least have the wife watching you and ready to assist should you need help.
A leak in the drain or pipe would account for the symptoms. It would drain water while the pump was off, and suck air while the pump was on.
And while I appreciate having to acknowledge the wife's input, it's not really up for a vote. Refilling a leaking pool can be just an added water bill expense, but it can also cause all kinds of other problems. Like undermining the soil under your pool, or deck, which could eventually be a catastrophic failure that would cost a whole lot more than $5,500 to fix. A leak can't be ignored, or voted away.
Welcome to pool ownership... 😏
When I bought my house with pool, I had no idea what a pool entails, nor was that explained to me by my realtor or anyone else (I had never owned a pool before). They look great. They're enticing. They look like nothing but fun. But then the reality sinks in. It's not like a patio that needs little or no attention. Or a lawn that you can ignore and let die and remove if you don't feel like having a lawn any more. Nope. A pool is forever. You can't ignore it. You can't stop taking care of it. You can't leave it alone when you travel. And you don't have much of a say in what it costs to maintain. It costs as much or more to get rid of it than it does to put one in. Even just filling it in can be a major construction project. And it doesn't leave home at 18 and stop costing you money. No, by the time it gets to be that age, it actually gets even more expensive! And that's if it was built well and taken care of before it became yours. It's a dirty little secret that we've all had to learn on our own...
So the only thing to do is enjoy the heck out it. Invite your friends and family and neighbors to enjoy it, too. It's going to cost you either way, so might as well get as much joy out of it as possible to make up for the expense. I automated the heck out of mine, so it's really not much work. But I regularly squirrel away some money for it, because I know it'll need some work eventually. Don't get me wrong, I like mine, and I wouldn't trade it away. I just had to adjust my expectations about it. Something you and your wife will have to eventually do, too.
Reactions: InyoRich
PS. Do you only have one drain cover? Not two? They used to build pools with just one, then it became law to have two. And I can't remember if it's State or Federal, but any work done to a single-drain pool sometimes requires the installation of the second drain. So that might account for part of that $5,500.
Good news. The pump is no longer sucking air. A warranty tech was out and cranked down the bolts on the pump as a first attempt, but the pump still leaked. Next trip out they replaced the O-ring and the pump no longer sucks in air, so the cause was the pump and not the leak all along.
As far as the leak, I called the company that did the leak detection and they said it was not the pipe that was leaking, it was the fitting. I have switched off the main drains and while I am still losing some water, it is less than what it was while having them open. I'll set up a wifi enabled pool filler and periodically check the level from my security camera while I'm away. I'll address the leak when I am back late Spring.
Thanks everyone for their comments & suggestions
Reactions: Dirk and oledan
