I thought I had a pressure side leak, but volume loss accelerated over the summer, and it continued after I turned off the pump. On the eve of closing, it’s below the level of the light. I’m actually putting water back into the pool and will have to continue thru the winter.
The plan is to address this in the spring. Pool company, without doing any diagnostic work, thinks I will need to contact a builder to do pool resurfacing. Any pitfalls I need to be aware of here, and do we need to rule out a main drain/floor return problem first? Dreading a big construction job…
