I put together all of my PVC and hoses. Found one leak that I have since fixed with an added gasket. And now I still have this leak. In the picture, you’ll see that I have an arrow pointed at this threaded fitting at the top of the tee.
It absolutely refused to not leak, so I used the same PVC primer and cement that I used on the slip fittings, but there is still a leak. At this point, is there anything I can do to stop the leak?
