- Mar 15, 2022
- 89
- Plaster
- Pentair iChlor 30
First, let me say I’m not at my house so all info is coming from house sitters, helpful pool cleaner guy and the plumber who did all the original work.
my pool began leaking and went through these detection steps:
turn off the pump.
use dark dye to detect any leaks. None found.
examine structure for cracks, in and out. None found.
let the water drop past the skimmer. Didn’t stop leaking.
let the water drop past the return jets. Didn’t stop leaking.
shut down all power to pool equipment, all valves off. water stopped dropping.
Plumber determined the drain valve in the pump room is the problem.
no water anywhere near pool equipment.
plumber tells me he will replace drain valve.
he comes to do the work, does something…
tells me there was sediment and something in the pipes for drainage…
should be fine now.
his bill includes labor for replacing valve and the cost of valve.
the water stops leaking for a few days, then starts again.
It’s losing an inch every 9 hours.
pits a 9000 gallon pool.
14x 30. Not deep.
my house sitters have turned off the skimmer so it doesn’t suck air.
pool cleanger tells me the valve was not replaced.
it’s the exact same valve. No cuts made in pipes, the same handle with the same label.
I don’t know what the plumber did.
don’t know why it held for a few days, don’t know why it started leaking again.
I suspect the diagnosis of faulty valve is still correct.
any thoughts?
thank you.
marcia
turn off the pump.
should be fine now.
14x 30. Not deep.
any thoughts?
thank you.
marcia
