Leak detected on skimmer line
Flying Tivo
3,100
Monterrey, NL, Mexico
Pentair Intellichlor IC-40
On the new pool at the ranch, i finally narrowed it down to a skimmer line leak. Its a quite fast leak with pressure but slow with suction. The good thing is that the skimmer line goes directly to the equipment pad(i have 2 skimmers). My question is how do you try to locate exactly where it is? A good portion of the pvc pipe goes through the shell. Is there a way to pin-point it? For now im working with just 1 skimmer.
I know some of the pros will use "deck plate" listening devices that really get location specific. I'm sure there are other methods. Can you post a pic or two of the surface area where this suspect suction line runs?
I’ve gotten lucky a few times pin pointing leaks under ground with just using a plumbers bladder. As long as it’s not under concrete, I run the bladder with all the valves open and the water sometimes surfaces.
