Thanks in advance if you can help me...
I did an overnight bucket test to see if I am losing water or it’s evapouration... it’s a leak I am losing about a 1/4 of an inch.
There are no visible signs around the pump equipment my waste line is buried but I have checked the spider gasket in the multi port valve looks good, no splitting, I then remembered we replaced the multi port valve last year. The eye glass has no visible sign of water passing through so I concluded it’s unlikely the back end.
I have no bubbles in the return line or in the basket of the pool pump, so I assume a leak in the plumbing doubtful?
I have no light fixing in the pool.
Now I am stuck... what’s strange is we seem to lose the exact same amount of water it seems to get to this level then stop. But I am going to confirm that tomorrow and see if we lose anything else.
Where else do you recommend I look?
