LCD Screen on Pentair IntelliFlo bad
izzi
10
SoCal
Moved from here.
Were the buttons working for you when you had this issue?
My display is blank, buttons don't work, and the backlight is on. The pump runs the schedule even with the display disconnected but for some reason the "quick clean" led is on. I think it shouldn't be on during the scheduled run?
Opened it up, had some corrosion there. Cleaned it, and tried the hack with display padding - no luck. Any ideas?
Thanks.
Shoot, you're already one step ahead. This is a known issue (mine does it intermittently, too), but I think you've already tried the known fixes. @Jimrahbe, is there anything else to try?
Reactions: PoolStored
