So to make sure I am visualizing this correctly - where the existing white plaster is on the left and right walls, the long ones, that is going to have to AB and then the top waterline area, the bench including the front of it all the way down to the floor and above it up to the waterline, and the stairs on all sides, will be tile? And you are concerned about the two areas of existing white plaster in the photos right now that are below the waterline tile area but above the stairs and bench? It looks to be about 8-10".
If that is correct, I don't think it will look silly to have the little strips of plaster/AB on the left and right while the short back wall is all tile simply bc it will look like a cascade of tile from the short wall down and everything "on that wall" is covered in tile so it actually makes sense not to tile those two areas on the left and right bc they arent included in the focal area which is the back wall of stairs and bench.
Teal areas being tiled. Is this what you want to do? Bc I think it looks great
Hope I am understanding this correctly.
