HI all, I have a Laars Lite 2 LD325N heater. Worked through all problems last years, and only bringing it online now for 2019. Heater started and ran, but I was encountering pounding or banging and then I shut the heater down to investigate. I was led to understand that the waterflow may be restricted, which suggests that there was some debri in the lines. I opened the heater drains and pumped water, then opened the 2" line from the heater and again ran the pump. No issues, and no visual constraints on waterflow. I walked though the Jandy trouble shooting guide from
https://www.fwwebb.com/docs/gas/JandyPoolHeaterTroubleshootingGuides.pdf. I had no issues in getting 24VAC throughout except for the voltage at the VAL terminal on the ignition control. Based on the fact that this worked a day ago, I assumed that the ignition control is functional. The final step (step 9) is "Does the heater fire?" And, no it does not (not now anyway). So, if everything works, then I need to replace the gas valve. Otherwise, replace the ignition control. Does anyone have any experience with this particular problem? I am loath to blow money on a part that doesn't fix the problem. Thanks, Drew7ster
