Okay so update from my end:
Installed the new flame sensor and used a wire brush on the various terminals and connection points. I did note that some areas seemed cleaner than others, should I be using some sort of solvent at this point to completely remove the corrosion?
As for my testing, I tested the system without the flame sensor plugged in, and it kept running. I also tested the system with the flame sensor plugged in, and it also ran fine. However, I performed some additional tests where I had the gas line closed, and I clearly heard the system attempt to start, shut off, and then attempt a restart. (3 cycles total) I also ran a test where I would start the system normally, and after the flame started, close the gas line, and about a second later heard the system shut down, and then attempt relight procedures.
My question is: is there any other sensor that could be shutting down the system beyond the flame sensor? It seems very counterituitive to me, but it seems like the system does in fact run properly when the flame sensor is plugged in. However, for some reason when there is no flame sensor, the system doesn't seem to care and won't be shut down on that basis. In sum, I think my system is in fact working properly as long as a flame sensor is plugged in.
Thoughts?
Thoughts?
