Turns out, I had initially WAY overestimated the size of my inherited pool at 15k gallons, and was consistently overshooting when adding chemicals. I became suspicious when a carefully measured dose of Muriatic acid caused a much larger pH drop than expected. By doing careful measurement and logging of chlorine addition and precise testing with FAS-DPD over several days, I was finally able to determine that my pool volume is actually somewhere between 7000 and 8000 gallons, so I am now using 7500 as my benchmark. I would NEVER have been able to figure out how to do this kind of estimation without you guys! My last Cl addition resulted in the expected FC level to within 0.5 PPM.
Thanks TFP!
Thanks TFP!
