Hello, hope everyone is well. We are in New England and the weather is turning warmer so the pool is opened. We got a new 24 foot round 52 inch pool. We filled with 12 inches of well water while waiting for water delivery of ~8000 gallons(that's one delivery). That leaves us having to use the well for the remainder. I tried to get the guy to deliver 1/2 load but he wasn't interested. I figure we will have 8000 gallons from the delivery and about 5000 from the well. I know there is iron in there because we have always had it in the past. Also, we have been making bleach solutions to clean and the iron precipitates. We also have manganese, as we have black in our toilet tanks.
So finally after that long winded intro, could I have some advice on how to add the chemicals so that we do not precipitate the iron? I currently have a CU-later 4 in there and the filter will be going tomorrow. I've added nothing else.
These are my numbers using a Taylor Complete FAS-dpd chlorine kit:
FC 0.3,
CC 0.6,
pH very bright pink that did not register on the kit, acid demand 1 drop gave no change, 2 drops showed 7.0, this rapid change confuses me...thought it would be more gradual but I did it with two different kits and received the same result
TA-none
Ca Hardness 60, Water showed purple indicating copper or iron. I used in date laMotte strips for both metals showed and got negative results. I'm not buying this with the history we have of 20+ years having a pool with either iron or copper or some years both. I added 5 drops then proceeded with the test. It turned red indicating calcium hardness but only took one drop to turn from red to blue so Ca Hardness is 60.
Thank you in advance,
Mary
M
FC 0.3,
CC 0.6,
TA-none
Mary
M
