Hey Guys,
wanted to share the information that Kemtek, the makers of some pool chemicals have up on their website...please look at what they say about Conditioner CYA Level when using liquid Chlorine.
Quote:
Free chlorine -- the most active chlorine in pool water -- should be tested every other day and maintained at an ideal range of 1 to 3 ppm. In addition, you should test the chlorine stabilizer level at the beginning and middle of each season. The ideal chlorine stabilizer level is 30 to 50 ppm if you are using chlorinating tabs; if you are using liquid chlorine it is 75 to 90 ppm. Short-term chlorination If you are starting up the pool for the first time, or if the free chlorine range falls below the 1.0 ppm level, add All-In-One Chlorinating Granules or Chlorinating Liquid to the pool as a sanitizer. Note: Be sure the water is balanced first (proper pH level, total alkalinity and calcium/hardness levels achieved first.)Long-term chlorination After the pool is up and running, you can use chlorine for long-term chlorination. Our products include:
What’s that all about? I posted this mostly for amusement of those here that really know about pool chemicals. To someone like me, I find it quite annoying to find that much contradictory information.
Happy Memorial Day Everyone! My test kit should be here by May 31st - meanwhile I am just brushing the walls daily and using a crappy test with dilation to roughly keep the chlorine level up
