Hello , I have a whisperflo 1hp single speed pump that was coupled to a 1hp motor. It was leaking from the right lower area (as seen from the front) and I thought it was a shaft seal.
In the process of replacing i figures the pump and seal plate were not salvageable
So I got a new identical pump, new shaft seal, new seal plate (generic with the seal plate gasket installed , new impeller). So the only thing that wasn’t new was the diffuser.
So I put it all together and now it leaks from the middle of the seal plate bottom.
Any advice is appreciated
