I have a pool with an attached spa setup in a standard configuration. When I turn on spa mode, the two JVA 2440 actuators typically rotate clockwise in sync to allow increased water flow into the spa returns and for this water to be drained by the spa drains. When I go back to pool mode, these two actuators rotate counterclockwise to their original positions. However, just recently one of these actuators occasionally does not rotate counterclockwise to return to its original position but instead continues to turn in a clockwise direction to get to its original position. It seems to happen randomly. I believe the cams are set correctly and the 1-OFF-2 switch on the actuator is also set correctly. Any ideas what is causing this? The actuator itself (which is 19 years old), the PCB or anything else? Any insight would be greatly appreciated... thank you.
