HI all. First year pool owner here and just wanted to check in and make sure my chemistry looks alright. Here are my test results from 5 min ago.
fc: 6
cc: 0
ph: 8
ta: 70
ch: 50
cya: 50
I think I've got a good handle on the fc. I add about 50oz of 10% each night according to Pool Math. Temps here are ridiculously hot right now and my pool gets a lot of sun, but the pool gets pretty light swim use. Does this sound about right?
I've only ever adjusted the pH once because it was a tad low and it's always been around 7.6-7.8, this is the first time I've seen it above that. If I understand correctly lower pH is the bigger issue, so not sure if I need to adjust down now.
I've raised the TA from 30 to 70 recently and according to the app this is a good place to be.
I really have no idea about the CH so I've never adjusted it. According to the app I should be at 250.
CYA is another one that is tricky for me. Is 50 good spot to be in for the amount of sun my pool gets? I feel like 50oz of chlorine a day isn't terrible as it comes out to about $36 per month. I check it every day around 9pm and it always will drop from 6 to around 2-3. I just want to make sure it's doing its job killing bacteria.
Let me know if anything looks out of line, I just want to make sure I'm not overlooking anything. Thanks!
fc: 6
cc: 0
ph: 8
ta: 70
ch: 50
cya: 50
