system has now been running for about 24 hours, appears to maintain fairly steady PH.
as a test to see how it adapts, I dumped half a box of borate (still slowly adding borate..) and PH rose close to 8.0
the Simpool PH came on and has been injecting slowly small amounts of Muriatic Acid into the line, PH was down to 7.4 this morning. I had dialed it to 7.3 on the controller.
one question I had was, how do I control the airlock/vacuum that is created by the peristaltic pump? I drilled a small hole through the cap of a Home Depot 20% Baume MA 1 gallon bottle and I can visually see the sides of the bottle are buckling inward as the pump keeps suctioning MA in small amounts. it's no problem releasing the pressure manually but I do need to create a small pinhole into the cap to allow pressure to equalize. the pinhole would allow some vapour also to escape. what's the best way to handle this?
