Just overwhelmed
Can’t believe I have been doing my own pool for 9 months or so now!
I have been keeping my TA in the 60 -80 range, and my PH was always rising. I hadn’t checked my TA in a while, figured it was fine. My PH hasn’t been rising at all either, stable between 7.8 -8. Just checked my TA and it was at 100, which is high according to TFP. My initial reaction was to lower it to TPF range, but, should I? PH has been more stable with TA higher.
Is there anything wrong keeping the TA at around 100?
Also….i think I have a leak somewhere. I might need a new post for that. Bubbles come out of the returns, and have been for a while. It’s really bad when the pump has been running at a low speed or was off overnight and then moves to a higher speed/turns on. Lots and lots of startup bubbles there, but the water is full in the pump. Changed the pump o ring, and that didn’t help.
Recheck all your connections at the pump. I was having the same issue. I disassembled all the joints, cleaned and lubed them and I think the issue it resolved. Going to wait a couple more days/start ups of the pump before I claim victory, but it looks good so far.
