- Jun 22, 2017
- 861
- Vinyl
- CircuPool RJ-45
At this point am I slamming the pool? This is kind of what lead me to the draining process because my water was getting algae too frequent. The steps were to lower cya then SLAM. I actually want to do this because I do not want to start seeing another algae bloom
Such a long thread I forgot where it started, lol. Double check your daughter's number, then raise your CH. Then you can start your slam. If your CYA is indeed 40, which is what I was expecting, your slam target is 16ppm. Raise it to 16ppm, then test again an hour or 2 later and raise back to 16. Keep doing this as often as possible, but no more than once an hour. You can test your FC using just 5ml sample and each drop equals 1ppm then, saves on reagent this way.
Keep at shock level until you can pass on OCLT. Also, don't worry about testing CC until you think you're about done, no point wearing that reagent.
