Hi all,
I have wanted a pool for as long as I can remember. At long last, we closed on a house with a masonry pool at the end of last year. Just for some background, its an oblong plaster pool, I did some rough measurements its around 21000 gallons. Manually chlorinated. I know very little about what the prior owner did.
We had the pool opened today and I have a company coming to an initially cleaning (couldn't do it same day...). I can report that the pool is dirty, cold and not green. Pump is running, heater operational. However, some DE was appearing at return when they went to top it off, so I will be taking the filter apart this weekend.
I have my TF-100 test so I ran some initial tests.
PH - 7.8
CL - less than 0.51 ppm
CH - 225ppm
TA - 60
CYA - 20
So, aside from the PH, everyone looks way low, which I have to assume isn't suprising since we just opened it up.
As for supplies, I went to Lowes and bought a bunch of Clorox stuff - Ph UP, Ph Down, Calcium Hardness Increaser, etc. I am learning that apparently aside from bleach, Clorox is not the way to go? It was all Lowes had but I can always return it and go elsewhere. I also picked up a few 128oz jugs of 10% liquid chlorine. I also bought some pool noodles and a ducky thermometer, but I don't think they factor in - those are more for my daughter.
The previous owner also left a tub of chlorine tablets (have to get specifics later) from Leslie Pools. The pool company that came (local) seemed wary about using them, and the Pool School articles led me to believe the tablets are more trouble than they are worth.
So I guess my question is what is the first step? PoolMath app recommended adding 81oz of liquid chlorine? Do I start with that, or do I need to get the CYA levels right so that chlorine isn't going to vanish like a fart in the wind? Or wait until they clean all the organic gunk out?
Thanks!
PH - 7.8
CH - 225ppm
TA - 60
CYA - 20
Thanks!
