Hi everyone,
Completely new here. So I purchased a home with an above ground pool. Once the cover was removed it was a pit of algae and resembled more of a swamp.
My initial water test levels were:
FC 0.12
TC 0.12
Ph 6.3
TA 0 adjusted due to high cya
CH 111
CYA 188
So, I added soda ash, circulated, and then double shocked the pool using Clorox Shock 6 in 1, I also drained about 50% of the pool and added fresh water. I’ve been running the filter nonstop.
I had my water retested today. My levels are now:
FC 1.71
TC 1.81
Ph 7.1
TA 20
CH 72
CYA 90
The pool is still slightly green and cloudy. I was going to vacuum to waste now that the water is a bit clearer. Thinking that will allow me to clean and lower the water levels to add more fresh water so I can lower the cya levels more. I’m completely new to all of this and learning as I go. Looking for advice on whether or not I should start adding more chemicals or what my next steps should be in order. Which do I focus on getting balanced before attempting to balance others, or should I worry about them simultaneously? I’d like to use the BBB method as I hear from everyone that it’s the best way to go. Any advice would be greatly appreciated!
FC 0.12
TC 0.12
Ph 6.3
CH 111
CYA 188
FC 1.71
TC 1.81
Ph 7.1
TA 20
CH 72
CYA 90
