I have a Taylor K-1005 test kit.
Pool is vinyl, 14,400 gal.
I put a chlorine floater with 2 3" tablets in it while we filled the pool from our well, nothing else.
As expected, chlorine is essentially nil in the test. I think it might be slightly pink, but not much.
pH is 7.2
Total alk 320ppm
Calcium hardness 320 ppm
When I tested for CYA the sample never "got foggy so you can't see the black dot".
So how do I start? I assumed I'd need to do a shock, and then test again to see where we land on values. Is that right? May need a little pH plus?
Help!
pH is 7.2
Total alk 320ppm
Help!
