- Apr 21, 2018
- 137
- Vinyl
- CircuPool Universal40
So I just burnt out my pump, I left it running, there's a ton of algai in the pool from over the winter and it kept clogging the de filter, so I left for work and I came back and it wasn't running, it hit the safely temperature shut off or whatever,
It'll turn on, but it won't pump much water, then it shuts off after 3 or 4 seconds,
It probably overheated from not cycling enough water through it
I was about to buy a variable speed replacement motor from inyo, now I don't know if it's just the motor that went bad and I can still do that, or were some of the pump parts damaged? Should I buy a whole new pump?
No idea
No idea
