Just Bought E30 (S200) Robotic Cleaner, what to do with Polaris Pump and Plumbing?
Jul 22, 2018
34
Fayetteville, Georgia
Pentair Intellichlor IC-40
Just went Robotic E30(S200). Should I plug up the nossle where the Polaris 3900 used to connect? Even with Booster pump off there is still a fair amount of water pumping out of it. It’s on the opposit side of the pool and between my jets. Will that effect my skimmers. Should I plug it up. What should I do with the booster pump and associated plumbing?
You could screw an eyeball fitting on the end and leave it as an extra return. I plugged mine and sold off the pump, but I think I’d like to plumb in a water line to make topping off the pool a little easier rather than dragging the hose out. If I could figure out a way to make it a siphon drain as well for wintertime, I’d be super happy.
Be careful plugging it though since it won’t have chlorinated water going through it anymore. I need to fix that on mine.
I left mine as is. Yes, a little water flows through it but it's fairly minimal. I left the pump attached as well, just pulled the breaker for it.
