June contest! Submit photos for the visual encyclopedia!
Wal-Mart HTH 2-way Test Kit
Wal-Mart HTH 6-way Test Kit
Wal-Mart HTH 10% Chlorine ($2.50/gallon)
Leslie's Liquid Cyanuric
Sometimes you can't wait for the granules to disolve
Homemade Pool Toy Storage
1 1/2" PVC, 30" vertical pipes, 12" legs, 7" spacers
Homemade Aerator
1 1/2" PVC, 72" spray bar w/ about 60 1/8" holes
Inspired by Gooserider's similar project
Multiport valve
Chlorinator
For those 3" pucks I don't use anymore
Gas Heater
Notice it's 89 degrees (it's been very hot this week)
Automatic Pool Cover
This may be unusual. I've got an automatic pool cover that's quite manual.
Cover Pump
Rule 1800 GPH
Zodiac Baracuda G3
Automatic pool cleaner
Rubbermaid storage cabinets
Small pool toys, goggles, towels, sunscreen
I think the visual encyclopedia is a great idea. If you would like a close up of a particular piece of equipment just let me know.
Hopefully you will find a few pics you can use. The first link is a page I created that documents the installation of my 15 X 32 fiberglass pool. The pics range from digging the hole to finishing the concrete.
Pool Construction
http://bakerlabs.com/pool.htm
Flying Fiberglass Pool
Complete Setup, Pump, Valves and Filter, including plumbing for solar heater
Close up of solar diverter valve, isolation valve and two check valves
Solar Panels
Solar Panels Detail
vacuum adapter
safety cover springs
motor bearings
light gasket
bag net
solar cover reel straps
super pump lid gasket
port valve top
port valve top side view
diffuser
hayward cleaning wand
hayward skim vac (vac plate)
cl100 chlorine dispenser
main drain plate
knobs for pumps
water bag
ground up white goods (for use with Shmear)
sea-klear copper algaecide
