- Jul 29, 2008
- 318
- Plaster
- CircuPool Universal40
I was replacing the o-rings on my Jandy valves because they seemed to be leaking air. I discovered that one valve had the grease port plugged. Perhaps it broke and someone was looking for a a cheap fix.
Amazon has replacements for $23. Should I replace it?
What is the correct use of grease ports? Give them a turn every month or so or what?
Thanks for any advice!
Amazon.com: Jandy 2133 Gray Valve Grease Cup Kit Port Valves for Pools : Patio, Lawn & Garden
www.amazon.com
