I am going into my second year using the Jandy SWG. Last year worked perfectly, no issues on opening/closing. This year after opening the pool, things seemed to be operating fine. The aquapure panel and iAqualink app operating like it should. Several days later however, I went to check the status in my iAqualink app on the phone, and there is no indication that the SWG is running. usually there is a line for salinity and % output. I go into the menu->set aquapure and I get a "Aquapure not found. Check Aquapure RS485 and power connections". I run down to the aquapure panel and it is powered up but the cell on led is our and the cell resting, flow and cell reversing led are light. I have attached the images of the aquapure panel and aquapure paddle. Salinity is 3.2 and water temp is 72. Not sure what the problem is. Any thoughts or ideas. Thanks in advance.
