I have a Jandy RS board with iAqualink 2.0 antenna plugged into the second comm port. I had an old RS/4 inside control panel plugged into the first comm port ... but it recently started causing some type of interference with the iAqualink 2.0 and so i had to unplug it ... maybe the first comm port is bad?
Either way I have a Inteliflo VSP and would like to run the control cable to the Jandy RS. I have seen where techs will wire two devices such as an inside panel and outside spa controller to the same comm port. Is it possible to do the same to have Intelliflo and iAqualink 2.0 connected to same comm port on the Jandy RS?
If not, do i need to buy a separate comm expansion board to the Jandy RS?
