- Jul 15, 2017
- 3
- Vinyl
- Jandy Truclear / Ei
Has anyone dealt with Jandy pool light warranty replacement, I can’t find anywhere what their warranty period is? At the end of last year the pool light wouldn’t turn on, since nothing had happened that would cause any damage, I assumed it just needed a new light bulb. I pulled the light out today to change the bulb and noticed excessive rust/corrosion where the cord goes into the light housing. I cleaned it up as best as I could and tried a new bulb but it did not work. My assumption is that the seal where the cord goes into the housing was bad and allowed water seepage into the light. Attached are pics of the assembly, this is after I cleaned it up a bit.
I’ve disconnected power to the light until I can get it sorted out.
Anyone had a similar experience and did Jandy warranty it?
