Daughter's ~10 year old heater is showing a FL4 service code. It had been running for a number of times in prior weeks.
FL 4 (igniter) code and steps from manual:
Ohm meter on each ignitor was between 30 and 300 ohm (like 85 and 140).
Reinstalled old ignitor and she gets same service code and failure to ignite.
Any ideas on what to check next?
- Igniter circuit is open: Check fuses on igniter wires. Identify and correct loose connections or broken wires.
- Element has a fine crack in it: Measure room temperature resistance and ensure value is in the correct range. See manual for details.
- Igniter fault: Replace igniter
