Jandy LXI high limit switch position
szadorian
1
Glendale, CA
I purchased Jandy High Limit Switch Assembly, R0457400.
one of the sensors has a red dot. is there a difference which sensor goes where?
Also when I removed the sensor there was a sort of glue on the sensors. do I have to put anything on the sensors before screwing them image (47).pngin?
Welcome to TFP.
One switch is for 135F and one switch is for 150F. I am going to assume the red dot switch is the 150F switch.
Their positions in the manifold should not matter although the right most is the 150F.
Let's see if @1poolman1 confirms this.
