Jandy LXi - Fuse Link Fault
Jul 9, 2014
3
Canada
Ran my Heater for a good 15-20 hours this year. Recently getting the 'Fuse Link Fault' Error'.
When I turn the heater on, the fan starts. A little while later it ignites and I can feel heat being exhausted off the top. 20-30s later it stops with that error. It then retries a number of times unless i turn it off.
My next step is to go through the troubleshooting guide when I have a bit of time.
Jandy LT Pool SPA Heater Troubleshooting (Zodiac guide)
I did take a few pictures i wanted to get an opinion on. I took pictures of both fuse links.
IMG_20190619_2057500.jpg is the one near the exhaust. I understand its a one time use and will burn out. It definitely doesn't look like the other fuse, but wasn't sure looking at it visually if its shot. I also notices the wire connections were much darker.
While i look to replace that Fuselink as a first stop, can I also bypass it to confirm those wires are good. Or is there something I can do with the mutimeter to test.
Thanks.
