have a jandy lxi. Run on propane. it started by giving me a check ignition control error after it would fire up and start to heat. Then it would kick off and show check ignition control. Had a pool guy out and he suggested to replace the control power interface board. Well that worked! But now it will start, will run again, fires up and starts to help and then shows check ignition steps. I have ordered a new hot surface ignitor for it as well but it came broken. Any other ideas?
Thanks
Thanks
