I have an older model Jandy LRZE pool heater and it is giving the IGN fail error. I have dealt with this before and typically resolved it through replacing various parts. This time is a little different and I couldn’t find anything in forums with these specific symptoms.
When the heater goes through the IGN sequence, everything works like it’s supposed to up to the moment the Fenwal is trying to power the gas valve. When the gas valve is powered it immediately end the IGN attempt.
I pulled the connector off of the “Valve” terminal on the ignition controller, and I am only getting 12v when the ignition controller send power to that terminal. If I connect the wire from the ignition controller to the valve I get 6-7v at the end of that wire.
I purchased a new Fenwal ign controller. Replaced the wiring from the Fenwal to the gas valve. When the Fenwal tries to power the gas valve it immediately drops out. I still am getting 12v at the Fenwal terminal and 6-7v at the gas valve.
Is this an issue with the ground?
