Hello, I'm looking for some help diagnosing and repairing my Jandy LRZ Pool/Spa Heater. We've enjoyed many years of trouble free use until recently. To make a long story short, the heater was running on a very hot day. The heat exchanger fins got clogged up with a sooty fine black powder. This restricted the airflow and caused a flame rollout and the unit shut down. After removing and cleaning the exchanger I tried to start the unit. It would cycle 3 times and lockout with no glow from the ignitor. I then noticed the two wires that go to the hot surface ignitor had melted together. The flame sensor wire was also damaged. I replaced both the sensor and ignitor. The unit cycles but the new ignitor does not heat up or glow either. After three attempts it locks out just as it did prior to replacing the damaged parts. I assume the ignition control box is fried but don't want to invest in one without confirming that's my issue.
After looking over the manual https://www.jandy.com/-/media/zodiac/global/downloads/h/h0299500.pdf I noticed the ignition control isn't wired like the manual shows it should be as far as the hot surface ignitor is concerned. One lead goes to the junction block as it should and the other is attached at line 2 as opposed to IGN 120.
If anyone could recommend how to test the ignition box or how to best proceed it would be most appreciated.
