*I did do a search on this FYI*
So I have two Jandy WaterColor LEDs.
I am using the iaqualink, as well as the web version.
I may not be understanding this correctly, and thus doing it wrong. I thought per the instructions that if I choose a color, shut off the lights for 7 seconds, turn back on, it will default to that color?
Right now, no matter what I do, when I turn on the lights, it starts at the beginning and cycles to that color I chose. if I choose a different color, it again starts over and cycles till it gets to that color.
Is this by design? Will it not just change to, just using this for example, if I have it on green, and I choose blue, it will just switch to blue? It wont go through white, orange, yellow, green, then blue?
The other thing I am noticing is that when I do turn on the lights, it will start at the last one used for a second, then cycle through till it gets to that color again.
Can this system not just switch to a new color without cycling?
Can this system not turn on and default to the last color used, and just stay there without cycling?
