Hello I noticed my jandy auto fill has not been able to keep up with keeping the water mid way on my pool tiles. I did check to see if levelor is working and the sensor light does turn on and I checked to see if water was going into the pool and it did although the pressure was less than where the pump blows water into the pool. The jandy levelor does push water into the pool each time for twenty minutes before it shuts off. The past three years I never had this problem. I’m wondering if there is a part that may be going out that does not allow for as much water to go into the pool. Thank you for the help
We also have not been swimming in the pool last two weeks
