I’ve got a JXi gas heater that won’t turn on. On the IAquaLink it appears as though it starts and is running, however doesnt start up at the equipment. The pool water temp on IAquaLink shows 71 degrees and that is accurate. On the Jandy JXi display it shows the water temp is 108 degrees. (Def not accurate). It’s showing the 108 degrees for both pool or spa mode. I’m assuming there is a separate temp sensor in the heater. I’m assuming that since the heater thinks the water temp is above the set point that the thermostat is not calling for heat and thats why it won’t fire up?
Any suggestions? Id like to try to diagnose and repair anything simple before calling a technician once I feel out of my league.
Thank you.
Thank you.
