I see there are many people that seem to get this error and from those posts I have learned a lot to check for.
The usual solution from what I have read is to check the sensors or the ignitor.
I checked the resistance on the ignitor and it seems to fluctuate while connected but within the tolerance that I could find online. Min is around 60 and online says ~10 - 100.
I have also watched the ignition sequence. Looking through the view port, I definitely see the glow which tells me the ignitor is lighting up, but the propane does not seem to igniting to flame.
I definitely smell propane after the failed ignition as the blower evacuates the drum.
Could the ignitor just be lacking the oomph to get a spark? Could there be too much (or not enough) air mixed with the propane? Could there be too little propane?
I have verified that the air sensor sits open (infinite resistance) when off and when the blower kicks in it goes to close (0 ohm). I have checked the hosed and all feel dry and appropriately flexible and clear when I blow through them.
The water sensors also seem to be functioning correctly based on the Ohm meter.
I should also mention that the heater was working ok earlier this season and shut everything down before a big rain storm and then left it off for the week since we were not going to be swimming. I turned it all back on in anticipation of a nice weekend and I have not been able to get the heater to spark back up since.
Any assistance would be greatly appreciated.
