Jandy JXI went dark. I have replaced the transformer and the Power Distribution Board (PDB). The input power to the PDB is a solid 240+ VAC. The output from the PDB to the 204v side of the input for the transformer is only 37 VAC.
This is supposed to be around 240v to power the transformer. I have checked everything I can think of - the grounding is good. Even swapped out another PDB in case the one I received was bad. No fix.
Heater is still dark.
Anyone find this issue where the output voltage from the E and F on the wiring diagram is too low (37 VAC) when it should be 240+ VAC?
