Moved from Here
Did you figure it out? Mine is doing the same thing, I can hit the gas valve with my hand when it starts buzzing and then it will usually ignite.I feel you brother. I have done everything in this post. I get almost the same resistance on all my contacts. At this point I have replaced all connectors just to rule anything out. Only time I can get an LED light on the CE wall is if I turn solenoid on gas valve to “off”, a d turn off gas supply. Then i get three blinks. I have checked for gas, which I have. Not sure where else to go. Seeing as you have replaced your valve already, not sure that will even help me. If you get a solution let me know!
