Hello all, I have two JVA’s that are making sound and vibrating but the valve is not moving any ideas? Just started this season after opening. The valves are only 3 years old.
You can Google this for more info if you need it, but try to operate the valves in manual mode. Loosen the nut on top, but don't remove it completely. Push it down while turning the handle to check that the valve is moving freely. Tightening down the nuts too tight makes the handle very difficult to turn. When you resecure the top nut, don't tighten it too tight.
